Question on bracing top from Scott Antes plans http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=16813 |
Author: | ChuckH [ Thu Apr 10, 2008 6:25 pm ] |
Post subject: | Question on bracing top from Scott Antes plans |
Some folks say that the Scott Antes plans from LMI are braced too top heavy. What in particular would you change? I'm building a D-28 style and at the point where I'm going to cut the brace wood in the next couple days. I'm not going to put the popsicle brace in but instead install a brace that wedges in tightly between the neckblock and soundhole, something in the order that Bryan Kimsey advises. What's your opinion? |
Author: | grumpy [ Thu Apr 10, 2008 9:51 pm ] |
Post subject: | Re: Question on bracing top from Scott Antes plans |
The entire pattern is wrong. Toss it, and get yee the StewMac herringbone blueprint or the Martin dread print(same exact print) |
Author: | ChuckH [ Thu Apr 10, 2008 10:11 pm ] |
Thanks Grump, I'll do just that. preciate it |
Author: | Jeremy Douglas [ Fri Apr 11, 2008 6:50 pm ] |
grumpy wrote: The entire pattern is wrong. Toss it, and get yee the StewMac herringbone blueprint or the Martin dread print(same exact print) Whats wrong about it? That the plan I got ![]() |
Author: | bluescreek [ Fri Apr 11, 2008 7:34 pm ] |
Antes plan isn't even close . The bracing is not correct and way too heavy. Martin bracing is 5/16 and the height is wrong also. Even the stew mac is off but it is closer than the antes. The martin print is also the same as the stewmac but with their name in the title block. Note that unless a print is marked "SCALE" the drawing is representational. Go by the numbers and not what you see. The print may infact be correct but don't count on it. Also if the print appears to be a copy , paper stretches so again don't trust your eyes , trust the numbers. john hall blues creek guitars. |
Author: | Jeremy Douglas [ Fri Apr 11, 2008 7:44 pm ] |
Oh, I was going to use prewar brace dimensions anyway. I measured my plans to make sure they were to scale and they measured ok. I couldn't think of any other way to build the external mold. |
Author: | Frei [ Fri Apr 11, 2008 9:03 pm ] |
What are the prewar brace dimensions? Are they listed on a Martin site? Im doing a dred(s) to the Stewi mac plans. Got em from LMI, but they say Stewi Mac! |
Author: | Jeremy Douglas [ Fri Apr 11, 2008 10:03 pm ] |
Frei wrote: What are the prewar brace dimensions? Are they listed on a Martin site? Im doing a dred(s) to the Stewi mac plans. Got em from LMI, but they say Stewi Mac! There's not actually specific dimensions. The X brace was about 5/16 x 5/8. I was refering more to the pattern than the size though. here's a link about 'forward shifted bracing' http://www.stewmac.com/tradesecrets/ts0 ... clk=191731 |
